Вот нарыл тут про
epoxy SUP boards. Говорят, что чехол зло :)
Источник:
http://www.seabreeze.com.au/articles...d_4799527.aspx
DONT COOK IT!
You’ve got your new board, you love it! The last thing you are thinking is that it can potentially be a hot air balloon waiting to explode. Yes, your board is really just a big container of air. Heat it up and POP - its all over. The styrofoam in the core of your board is largely air. Even though these boards are designed for the ocean and the beach, they don't like extended exposure to heat.
You board is not covered under warranty if you overheat it so here are some tips to avoid ruining your board.
Things to avoid:
* Leaving your board on the roof of the car for extended periods in direct sunlight or on hot days.
* Board bags actually make things worse - they help 'cook' your board.
* Leaving your board in the car also helps to 'cook' it.
* Radiant heat through windows is your worst enemy.
* Bubble wrap is like a thousand magnifying lasses trying to destroy your board
* If you have a black or dark grip - flip the board over on the beach or put it in the shade.
* The lighter the construction, the weaker the skin, the more likely your board can be heat damaged.
* The darker the colour (Red, Blue etc) the quicker your board will heat up.
Вот еще
http://www.longmontsup.com/care-for-your-board.html
В основном ведут речь о том, чтобы не лопнула и не потрескалась.
Про термическую деструкцию пенопласта никто не вспоминает :)
Другими словами, если не вздулась и не лопнула, то выжила.
А вот что говорить Board Lady:
http://www.boardlady.com/heatdamage.htm
EPS foam outgasses at 130 degrees, Divinycell shrinks markedly at 130 degrees, room-temperature-cure Epoxy resins turn brittle at 130 degrees. The result at minimum is a reduced lifespan of your board. You may get away with a printing through of the reinforcements and inserts. But you may well end up with a bubble.
То есть, речь идет о том, что белый пенопласт (EPS) - это воздушный шарик и его распирает. А Divinicell (AIREX) тупо сжимается (плавится). И все это уже от 55 градусов цельсия.
Напомню, почему я всё упираю именно на SUP.
Все просто, они много длиннее. Мои виндсерфинг доски хорошо прятались в машине далеко от лобовухи и я слегка расслабился
от мер предосторожности. А тут купил SUP, она легла в машину большой поверхностью под лобовуху. Вот тут-то все и началось!
Придя проверить состояние доски (все таки я не полный по.уист) с ужасом обнаружил, что нос её нагрелся слишком сильно,
хотя на ней лежала простынка и пару отражалок.
